Need some advice
Flush the crankcase good with some engine flush and oil mixed. Drain all the old oil out, then put 2 bottles of engine flush and 3 qrts of new oil in. Run it for 15 minutes at idle. Then dump that out and put new oil in.
Yeah, have the tuner check everything possible.
Go drive it. You're not gonna know what little things need to be fixed till you start driving it.
Put the 3 qrts of oil in first so its sitting in the bottom of the pan. Then pour 1 of the bottles of flush in on top of the oil. Then start the engine. The oil pressure should pop right up. Then go over and pour the other bottle of flush in. Let it idle.
You don't want to pour the flush in first because as soon as you start the engine its gonna suck up that real thin liquid and thats bad for your bearings.
