Sponsored by: CARiD
EVAP system is jacked, help
Old Sep 9, 2009 | 12:15 AM
superbee_68's Avatar
Default EVAP system is jacked, help
I searched and got over whelmed with the amount of info. Basically the engine code is P0446- EVAP Purge Solenoid, so I replaced the purge solenoid because it was plugged in when the code was thrown. Also I have not changed anything to the car for months so this problem happened on its own. The same code still throws, so what do I check next?
Thanks
Old Sep 24, 2009 | 05:01 PM
still broken, no advice?
Old Sep 24, 2009 | 09:45 PM
98pontiac's Avatar
Thanks
when you say it was plugged in when the code came, does that mean you run it unplugged? is it a ciurcut malfunction code? or just a soleniod malfunction? where did you buy the soloniod? it may be defective...
Old Sep 25, 2009 | 11:45 PM
RA032926's Avatar
did you clear the codes when you changed the solenoid?
Old Oct 1, 2009 | 05:34 PM
ODAWG's Avatar
thats exactly what i was gonna say clear the codes first.
