Sponsored by: CARiD
need help fast on pinion angle
Old Sep 18, 2009 | 11:30 AM
blackws620's Avatar
Default need help fast on pinion angle
i broke my torque arm and changed my rearend at the same time. i got everything done only now i have an adjustable torque arm tunnel mounted. What should i pinions angle be?? also do you measure driveshaft angel instead or off the pinion?
Old Sep 18, 2009 | 11:37 AM
Slvr00Bird's Avatar
It should be negative 1 or 2.. You measure both, driveshaft and pinion or rear end angle and subtract the two (I can't remember which you subtract from which).. remember, a load has to be on the car though..
BMR has a video of how to set it.. search there site and that should help you.
