Sponsored by: CARiD
Brake Lights Not Working
Old Sep 22, 2009 | 09:42 PM
Gary98Z's Avatar
Default Brake Lights Not Working
The driver side, spoiler, and passenger side brake lights are not working. The bulbs are all fine and I haven't done any recent work to the car (other than drive it around).
Blinkers, headlights, and hazzards work fine.
Any ideas what to check? Where are the grounds? Are there any brake light fuses to check?
Thanks.
Old Sep 23, 2009 | 12:00 AM
98pontiac's Avatar
have you put in new bulbs? check the connection in the bulb make sure the socket connecter isnt melted or boogered up. there is a fuse but it is for all brake lights and I beleive your backlights in your dash gauges...
Old Sep 23, 2009 | 07:49 AM
wssix99's Avatar
Save the manuals!
If the rear turn signals/hazards work, then check the brake switch mounted to the top of the brake pedal. (Remove the lower IP panel to access.)
There is a plunger in the switch that is pressed in when you are not pressing the pedal. When you release the pedal, the plunger comes out and activates the switch.
Old Sep 23, 2009 | 05:57 PM
Gary98Z's Avatar
I did try replacing the bulbs, but no luck. The dash lights do work though.
I'll try checking out the brake switch next.
Thanks for the tips.
Old Sep 26, 2009 | 07:41 PM
Gary98Z's Avatar
That solved the problem. The dealer of course didn't have the $16 part but Oreily's actually had it stock for $10.
Thanks again!
