Sponsored by: CARiD
2001 SS broken wheel speed sensor
Old Oct 4, 2009 | 05:13 PM
Blue71Z's Avatar
Default 2001 SS broken wheel speed sensor
Well, when I was lowering my car I accidentally broke the front left wheel speed sensor. Because of that I now have no ABS or ASR, and those annoying yellow lights are always on. I called the dealership to try and get a new sensor, and they said that I would have to buy a whole new hub to replace that sensor. Before I spent $450 I wanted to see if anyone knew of some way to bypass completely replacing the hub, and just replacing the sensor.
Thanks
Old Oct 5, 2009 | 05:10 PM
davered00ss's Avatar
Moderator
General repair & maintenance will have an answer.
Old Oct 5, 2009 | 09:38 PM
firetpi's Avatar
As far as i know unless you get a junkyad hub and knab the abs sensor out of it etc.
The new ones only come as complete assemblys.
Old Oct 5, 2009 | 10:15 PM
98pontiac's Avatar
The sensors are build inside the hub bearing.. you must replace the whole thing... They arnt 400 dollars..... they are more like 150...
Old Oct 6, 2009 | 02:59 AM
FBDYLVR's Avatar
PM Sent. I got a couple laying around if you're interested.
