Sponsored by: CARiD
ac tensioner bypass
Old Oct 6, 2009 | 08:10 PM
ws6nick's Avatar
Default ac tensioner bypass
Bypassing the ac tensioner with a smaller belt.
I did a search and surprisingly found nothing.
Anybody done this? When I went to replace the tensioner the threads came out with the bolt. I dont want to spend $70 on a helicoil kit. So if I can, Ill buy a slightly smaller belt to bypass the ac tensioner and call it done. The squeaking is driving me crazy.
1.Will doing this hurt anything?
2.Anybody who has done this have a belt size?
3.I also heard that the goodyear gatorback belt helps the squeaking..... is this true?
Old Oct 6, 2009 | 09:59 PM
eseibel67's Avatar
The tensioner has a spring in it to keep the belt tight. If the mounting is stripped and the tensioner is not tight, how will a smaller belt help?
Old Oct 6, 2009 | 11:29 PM
ws6nick's Avatar
I want to NOT use the ac tensioner by bypassing it with a shorter belt..... I don't know if that is possible though.
Old Oct 7, 2009 | 06:39 AM
fleetmgr's Avatar
Only if you want to do an A/C delete. Without the tensioner there's no way to keep the belt tight, even if you do use a smaller belt. None of the other components are adjustable that way.
