Separating Lower Ball Joint...HELP!
Brandon
OP- make sure the taper side on the pickle fork is pointed down towards the control arm, the only thing i dont like about a pickle fork is it tears the **** out of the rubber boots, i think they also have a balljoint press you can use that will also remove it, and never hit the actual ball joint thread
