Sponsored by: CARiD
Pulling doors...
Old Oct 18, 2009 | 10:47 PM
blue99ta402's Avatar
Default Pulling doors...
Hello everyone, I'm going to pull off my doors on my 99 ta. Is there a plug I can unplug so I don't have to unplug all the connectors? Or do I have to pull the door panel and unplug al of them?
Old Oct 21, 2009 | 10:44 AM
ORedRoc4's Avatar
Pull the door panel, its like 4 or 5 screws/bolts, and unplug everything inside the door, and pull it through the rubber grommet. Remove the 4 bolts that hold the door on the chassis and voila. Careful the door is HEAVY if you still have the side impact bars in...
its very easy....
Old Oct 22, 2009 | 10:22 AM
9911UZ28's Avatar
1.Remove front side door trim.
2.Remove water deflector.
3.Remove electrical connectors from all components in door.
4.Remove wiring harness grommet (3) from door (1).
5.Remove crosscar and front side door wiring harness from door.
6.Remove door spring.
7.Support door in preparation for door removal.
8.Remove upper (2) and lower hinge nuts (4).
9.Remove door from vehicle.
Old Oct 22, 2009 | 11:26 PM
Thanks for all the info guys.. I'm going to pull this weekend..
