Sponsored by: CARiD
pass window: motor or wiring problem?
Old Oct 22, 2009 | 08:46 PM
mediocrels1's Avatar
Default pass window: motor or wiring problem?
my passenger window doesnt always work. itll go up or down bout half way then stop. then ill keep driving for a bit and try again and itll go up or down a little more and so on until its closed/open.
ive heard this is because there are resistors built into the motor that cut power when the motor becomes overly taxed...?
my question: will replacing the window motor remedy the problem?
i also found this kit...
http://www.ws6project.com/user_stor/...oducts_id=2055
thanks
Old Oct 22, 2009 | 09:10 PM
Spartan7's Avatar
Yes, the motor is on its way out. A new one will fix that. The kit you posted will fix how slow the passenger window is from the factory, and it works very well.
