Sponsored by: CARiD
Water pump knock?
Old Oct 28, 2009 | 02:14 AM
BladeX10's Avatar
Default Water pump knock?
I know the water pump just went out in my camaro and its pissing water everywhere but theres a knocking noise at a idle.. Its like a constant pinging noise that goes away when revved a bit. It never overheated. I found the leaking water before it had a chance to overheat. Is that noise apart of the water pump issue?
Old Oct 28, 2009 | 09:11 AM
fleetmgr's Avatar
I suppose it's possible. At any rate, you'll have your answer when you replace the pump.
