Sponsored by: CARiD
Another High idle ??
Old Nov 7, 2009 | 09:08 PM
FASTEDDIE Z's Avatar
Question Another High idle ??
Can oil or grease on a TPS sensor can cause this a high idle ?? I just put a P & P throttle on my car and had to swap over the throttle shafts . When I did ,I put a little shot of white lube on the end of the throttle shaft . I have a problem with my engine going to 1400 -1500 rpms then dropping down to @ 1000 rpms in gear when cold and gets worse when its warm (@ 1100 in gear ) .The Idle is still too high .The idle is turned all the way down too . Didnt notice this until after the T/B install .Im going to check for a vac leak tomorrow .
