Sponsored by: CARiD
driverside lean, bad cat also
Old Nov 8, 2009 | 10:21 PM
rich Z's Avatar
Default driverside lean, bad cat also
The driver side 02 is reading up to +12 at part throttle and cruising. At idle the even or close to even with the right side. I'm also getting some slight misfires according to autotap and a code for a bad left cat. I have already swapped the front 02's from one side to the other and no change.
Old Nov 8, 2009 | 11:52 PM
98pontiac's Avatar
the reading your getting seems to be from the 02 sensor behind the cat, not in front. if the cat is bad, you need a new cat. if it is a "efficiency below threhold" replace the cat and clear the codes. Or it sounds like you may have a leak in the exhaust near the cat, if so the code is as simple as fixing your exhaust leak. Converter repairs at a muffler shop run 45 dollars, and they will be glad to clear your code.
Old Nov 9, 2009 | 12:16 AM
rich Z's Avatar
I have a code,efficiency below threshold. However I need to find why I'm running lean on the same side. I had the same code about 6 weeks ago and cleared the code only for it to come back. Wouldn't running lean cause the pcm to the motor to run rich thus ruining the cat?
