QTP Electric Cutout Install/Issues
First, somewhere I obtained a new rattle under the passenger's floorboard. It is driving me nutz. First I thought it was a heat shield, then the Y-pipe, then the tunnel brace....now, I am leaning toward the flutter disc of the electric cutout itself....there is just nothing else in the area I can find. I know the new rumble is the culprit, because when I close the flutter, it goes away. Any ideas?
Next, the flutter valve itself only seems to want to open half way. I think the flutter is scraping the inside of the cutout causing it to stop, since it seems to open all the way when the flutter is off the car. Any ideas how to fix this?
Then, the toggle switch was cracked when I got it. It works fine, but I temp fixed it, since the side is cracked. I want to order a new one, but there are no part numbers on it and QTP is slow in responding to my emails. Anyone know where to get these?
There was an inline fuse for the power wire, but it had a 1A 12V fuse in it. It popped on me and i didn't have a spare, but this fuse is powering the toggle and the cutout itself...seems kind of low amperage for the setup. I just assumed it was correct. Anyone know for sure? Or do I just need to install a relay?
Now, when I was cruising home late at night after a long install and trouble shooting phase, I noticed a slight burning odor. I knew it wasn't the new wires, because the fuse had blown. I tracked it down to the light in the ashtray. I accidentally popped the spring off and the bulb was constantly on causing it to heat up the plastic shroud around it. Anyone have a picture of what it looks like installed, so I make sure I put it back correctly. I guess when I removed the ashtray the spring popped off and I didn't see how it was previously positioned.
Thanks for any ideas on how to fix the minor, but annoying issues.
