Sponsored by: CARiD
Vats question? not the usual one though
Old Dec 18, 2009 | 04:11 PM
DCfirebird967's Avatar
Default Vats question? not the usual one though
my car wont start, wont turn over but all accessory lights come on. except for the dome lights. my car is a manual and i can push start it and it will run or at least it did when i did it the first time. but i f i try with the key i get nothing. the security light isnt on (maybe burnt out idk) but if vats was my problem could i push start my car? or would it start up real quick then die?
Old Dec 18, 2009 | 04:39 PM
demonpixel's Avatar
My vats just prevents the starter from starting, really. We can start it with a screwdriver. So I don't see why push starting the car wouldn't work.
My vats is from a 93 though; it's the PASSKEY II system.
Old Dec 18, 2009 | 10:54 PM
slayerized6's Avatar
if VATS was the problem you would be have the "Security" light illuminated on the dash. My guess is that you got a bad starter or the connection on the starter is loose or you might just have a bad battery (not enough cranking amps)
Old Dec 19, 2009 | 03:43 PM
Spartan7's Avatar
Well I'm not sure if earlier systems were different, but I know on my 96 that VATS controls the fuel enable circuit as well, so you can't just jump the starter.
