Sponsored by: CARiD
idle
Old Dec 31, 2009 | 09:24 PM
c5z28's Avatar
Default idle
When I turn on the a/c say at a stoplight in gear(a4) the idle goes from smooth to rough. The oil pressure gauge goes from just under 40psi to just a little over 22psi and starts to wave. Idle can be fixed with a little foot in the gas and is fine when driving around but it understandingly bugs me. I cleaned the maf and no change so curious if anyone has any insight.
Old Jan 1, 2010 | 07:51 AM
lovin myls1's Avatar
Your not getting any codes?
Old Jan 1, 2010 | 12:00 PM
c5z28's Avatar
none.
Old Jan 1, 2010 | 04:01 PM
Well the PCM controlls the A/C clutch relay and when the a/c is turned on it is supposed to delay the clutch while the PCM adjusts the idle (up I would assume)-sounds like that is not happening.
Has the battery or PCM been disconnected recently?
Old Jan 1, 2010 | 10:58 PM
c5z28's Avatar
no
Run the heat just fine, it's when I go to a/c maybe a tuner issue then?
Old Jan 3, 2010 | 07:43 AM
eseibel67's Avatar
Dirty IAC motor?
