Sponsored by: CARiD
bad front end shaking
Old Jan 1, 2010 | 11:51 AM
poopshootSS's Avatar
Exclamation bad front end shaking
i have an 01 SS.and whenever i go to pull out of a parking lot and turn right my front end shakes real bad.the only way i can describe it is comparing it to when traction control is engaged in a front wheel drive vehicle. any help?
Old Jan 1, 2010 | 12:13 PM
MyFirstLS1's Avatar
i have seen this with bad control arm bushings. jack your front end up and shake down your front end. you sohuld notice it right away
Old Jan 1, 2010 | 08:45 PM
fleetmgr's Avatar
I agree with control arm bushings. And as you have to take it all apart to replace them, now would be a good time for a front end overhaul.
Old Jan 1, 2010 | 09:46 PM
lol sounds good.thanks for the help!
Old Jan 1, 2010 | 10:12 PM
MyFirstLS1's Avatar
if you have someone watch you drive it in a parking lot you should be able to see it shuttering. Not realy a bad job but i would check out all the bushings underneath the car. If the cntrl arms are doing it the other ones are prboably dry rotted and cracked/torn might want to think abotu replacing them.,
