Changing the power steering pump
going to need to aquire a power steering pulley puller tool apulley installer kit, (autozone/advance), and a drain pain, and want to place a plastic bag/cover over the alternator so the fluid doesnt leak on it and mess up the brushes (thatd be alternator #s 1 and 2 for me lol)
remove the accessory belt
pull the pulley off
place pan underneath car under pump
remove PS lines, one is held on with a cheasy spring clamp (ideal to replace with a worm clamp), the others a fitting around the back of it, might be tight
remove the 3 bolts holding the pump to the bracket
fanangle the pump out and put the new one in reversing removal procedure
dont forget to take the bag off the alternator before starting, hope i helped
