Sponsored by: CARiD
vacume leak
Old Jan 13, 2010 | 11:03 PM
jorgez28's Avatar
Default vacume leak
guys I have a vacume leak around at a hose that goes to the intake manifold by the throttle body where can I get a replacement has anyone done this?
Old Jan 14, 2010 | 12:03 AM
nemss1's Avatar
bring that hose to just about any parts store and theyll get u the size and cut it to length
Old Jan 14, 2010 | 02:22 AM
myk's Avatar
myk
Exactly. It won't be "factory" but it'll work-a hose is just a hose after all. Don't wait too long to fix it, either. I slowly started to lose gas mileage and idle quality and a 10 cent rubber hose would've fixed it...
Old Jan 14, 2010 | 01:17 PM
slow96z's Avatar
there is probably enough hose there that you can cut off the bad piece and slide it back on.
Old Jan 22, 2010 | 01:31 AM
jorgez28's Avatar
guys were does the hose unplug from? at the manifold there is a harder plastic piece does it come off from there?
Old Jan 22, 2010 | 04:48 PM
nemss1's Avatar
the rubber hose runs from a nipple on the passenger side valve cover to the nipple on the throttlebody
the hard plastic hose runs from the PCV valve to the intake manifold
