Sponsored by: CARiD
Drivetrain Buckling?
Old Jan 14, 2010 | 12:37 AM
Zerokube's Avatar
Default Drivetrain Buckling?
It seems sometimes when i shift i can feel the whole drivetrain buckle, think it could be a loose mount or something? its not terrible but its noticable
also just found out i have about 4 leaking gaskets (Intake, oil pain, rear end/pumkpin, and rear main seal)
Old Jan 14, 2010 | 01:58 AM
matt01ws6's Avatar
mine does that too. cant find the problem.
Old Jan 14, 2010 | 01:09 PM
fleetmgr's Avatar
Check the tranny mount.
Old Jan 14, 2010 | 10:42 PM
slayer_taunu's Avatar
most likely trans mount.
if its a street car, just get a poly mount. energy suspension is sold at most autozones. PN 3.1108 (its a universal GM mount, wont cross ref to 4th gen f-body... dont use the metal plate that comes with it).
if you go to the track, you shouldn't get a poly mount unless you also do poly motor mounts, as you can break bellhousings if your motor turns to much and your trans stays put.
