Sponsored by: CARiD
Non LS1 question for yall
Old Feb 2, 2010 | 01:03 PM
DarkJuggalo's Avatar
Default Non LS1 question for yall
Ok so my mother has a 06 grandprix, her rear brake hose was bad on the pass side, so i got a new one upon taking it off i realized the calliper had a crack as well, so im gonna change the caliper/brake hose, what exactly is the torque spec for the hose to the caliper so i dont over tighten it, and the bolt that holds the brake hose to the caliper has a hole for the fluid to pass through does this need to line up with the hole in the brake hose or will it pass through reguardless?
Old Feb 2, 2010 | 01:15 PM
Greekey's Avatar
It will pass through regardless. No need to worry about anything lining up. Just give it a good tighten.
fleetmgr's Avatar
The torque spec for the hose is "tight". Hole alignment won't matter. That bolt is called a banjo bolt, and it has a hole in it for the brake fluid to pass through. There may be a copper washer on the hose or stuck to the old caliper, replace it too.
Old Feb 2, 2010 | 01:17 PM
Greekey's Avatar
Make sure you get a brand new washer. Their called crush washers. If you don't change it, it will leak brake fluid. I learned the hard way. I believe their a once use washer.
Old Feb 2, 2010 | 02:59 PM
fleetmgr's Avatar
You can re-use them, you just have to anneal them first. The problem is usually getting it off without destroying it.
