Sponsored by: CARiD
exhaust/hole in floorboard problem
Old Feb 15, 2010 | 01:24 PM
dutinsss's Avatar
Default exhaust/hole in floorboard problem
well i'm in the process of sound deadening my camaro and i ran into a little problem. i have dumped duals and the hangers are welded to the same spots that the bolts that hold my rear seatbelts goes into. evidently the weld broke and the bolt was the only thing that was holding the exhaust up. when i took the bolt out, my exaust fell and left a nice hole in the floorboard.(one hole on the right and left). i'm thinking i'm going to have to get a piece of rectangular metal with a hole in the middle to act as a washer and use that and the seatbelt bolt to hold the exhaust up and run it to a shop to get it rewelded up. then use some sealer to seal up any small holes. i'll post some pictures but what do you guys think would be the best thing to do? thanks
Old Feb 15, 2010 | 01:29 PM
dutinsss's Avatar
i've got the exhaust jacked up and you can kind of see the metal that the bolt will thread into behind the holes.
