Sponsored by: CARiD
something weird i cant find an answer to!vid!
Old Feb 25, 2010 | 06:17 PM
slo_lt1's Avatar
Exclamation something weird i cant find an answer to!vid!
WATCH VIDEO FIRST
Ok i cannot seem to find ANY information on this problem im having.The previous owner told me it did this i thought ok whatever its probably just a loose ground i just want an ls1 he thought the same also claimed to have brought it somewhere and they told him it was but didnt find it and fix it. I have checked every ground i can find and there all good (can someone show me a listing of all ground points to make sure i got em all). It happens randomly and i can hear a clicking coming from one of the two fuse boxes under the hood when it does it. i really have no idea what to do i need to get it taken care of ASAP i am supposed to be trading the car very soon.
Old Feb 25, 2010 | 06:35 PM
joshp14's Avatar
Any codes being set in any module?
Old Feb 25, 2010 | 06:55 PM
slo_lt1's Avatar
dont know it wont drive because of other problems,last time i checked it just had o2 codes havnt driven it since new ones and it was doing this before that.
Old Feb 25, 2010 | 06:58 PM
joshp14's Avatar
All lights coming on in your video are controlled by the PCM. The PCM grounds to the back of the LH cylinder head. I would check that first. Also check to make sure the battery connections are clean and tight. Check the cable from the battery to the frame and well as the battery to the block. Check these and see if you find anything. Whats the condition of the battery and charging system?
Old Feb 25, 2010 | 07:48 PM
slo_lt1's Avatar
i tried to feel back there best i could and couldnt feel anything,battery to the frame is good bat and charging system is good
EDIT: smashed my hand back there and did feel one wire attached to the head, seemed tight
Old Feb 28, 2010 | 08:28 PM
matrik's Avatar
I've gotten that clicking sound from the dash when my battery connections weren't fully tight, but never anything with all the stuff flashing on the dash.
Old Feb 28, 2010 | 08:39 PM
RA032926's Avatar
i had that happen once on the first startup after i had my battery disconnected for about a week... i was like wtf!!... i jiggled the batery cables to make sure they were tight and saw a blue/green powder come out of the positive cable boot... so i ended up having alot of corrosion built up inside that boot and that's what caused all the dash lights to flicker on that initial startup... i cleaned all that crap out of the boot and haven't had a problem since
Old Feb 28, 2010 | 10:03 PM
epox4life's Avatar
I had the same problem but the car wouldn't start at all. Ended up replacing battery terminal bolts and took a wire bush to the terminals on the wires.
Old Feb 28, 2010 | 10:09 PM
matrik's Avatar
I should have also asked if you have tried replacing the battery
Old Feb 28, 2010 | 11:56 PM
slo_lt1's Avatar
no i havnt replaced the battery,it looks pretty new. ill check for corrosion in the morning
Old Mar 3, 2010 | 05:29 PM
slo_lt1's Avatar
no corrosion,also found out if your driving and it starts doing this it jerks uncontrollably!!!
Old Mar 3, 2010 | 08:19 PM
2000TransAm24's Avatar
Maybe the connections on the pcm? Try dielectric grease on the connectors? Could it be a bad connection on your gauge cluster? (kinda doubt it but maybe) Something somewhere is gotta be loose
Old Mar 3, 2010 | 09:45 PM
RA032926's Avatar
yeah that's a good idea, overtightening the 2 bolts that hold the connectors to the pcm can cause a bad connection
Old Mar 4, 2010 | 07:32 AM
slo_lt1's Avatar
ill check that out today
Old Mar 7, 2010 | 08:18 AM
matt_ss_205's Avatar
Mine was doing something similar. It ended up being the bolt that holds the negative wire to the terminal was stripped from corrosion, and it wasn't making solid contact. Bought a new set of bolts from Advance and solved the problem.
Old Mar 7, 2010 | 01:09 PM
DarkJuggalo's Avatar
def sounds like a pcm problem, i would check all the connections/grounds with the pcm.
Old Apr 13, 2010 | 08:13 AM
slo_lt1's Avatar
Just for anyone anyone else who might have this similar problem...it was my fuel pump!?!
I knew mine was bad but didnt think a fuel pump could cause problems like i was having,bought the racetronix kit and it fixed everything...well besides my headlights not going off but thats a whole different issue.
Old Apr 13, 2010 | 09:44 PM
chrysler kid's Avatar
sorry just saw this thread and my friends caddy did the same thing when the fuel pump was ran dry, then went bad shortly after
