Sponsored by: CARiD
someone SOMEONE HELP ON A P0133 CODE
Old Mar 1, 2010 | 03:35 PM
edward_garcia_69's Avatar
Default someone SOMEONE HELP ON A P0133 CODE
I been having problems with this code p0133 for a while ever since i replace my 02 sensor. Here are the problem that the code shows.
Slow response(heated oxygen sensor bank 1 sensor 1 ). The powertrain control module use the oxgen senor to calculate he air/fuel ratio n the exhaust.
Probable cause.
Oxgen sensor defective.
Fuel system running rich or lean check other codes first.
I just replaced the 02 sensor a couple of times alright.
Someone help fix this problem. Or what else to look for..
Thanks, eddie
Old Mar 1, 2010 | 05:24 PM
RA032926's Avatar
what kind of sensor did you replace it with?... some cars don't like bosch sensors and some work fine so that could be a problem... try switching the sensors from side to side and see if the code follows... if it switches over to bank 2 sensor 1 then your sensor is the problem and if the code stays the same then you may a problem somewhere in your wiring... also check the engine sensor fuse under the hood just for kicks
Old Mar 2, 2010 | 07:03 PM
thanks for infor. i will try to switch the o2 sensor soon. and if the sensor is bad what brand would the best to use ?
Old Mar 2, 2010 | 07:13 PM
LS6427's Avatar
Denso 234-4087 Oxygen Sensor.
Search that on Amazon.
My car WILL NOT run with Bosch 02 sensors.
Old Mar 2, 2010 | 07:52 PM
thanks, ill look in to it.
Old Mar 2, 2010 | 08:01 PM
Michael02hawk's Avatar
Ditto on that - my car hates the Bosch sensors too! I've been running the Densos for 3 years now, without a single hitch.
Old Jun 22, 2010 | 02:01 PM
senicalj4579's Avatar
anyone find anything out on this issue?
