Sponsored by: CARiD
Intake Backfire
Old Mar 13, 2010 | 11:42 PM
Boman6760's Avatar
Default Intake Backfire
Slowly but surely getting this project in shape. Recently added taylor wires, Long tubes and y-pipe minus all emissions. Emissions shut down. New O2's (OEM). MSD coil. Plugs done within last 1000 miles. So now I notice an intake backfire. Always there but more noticeable now that I have other problems ironed out. In park, nuetral, or any quick stab of the pedal it will sometimes do it. Not 100% of the time but more than enough. When I did the coil the ICM had some corrosion around it that concerned me. Could this be a cause? If not what else could I be looking at?
Old Mar 14, 2010 | 12:56 AM
biggb1783's Avatar
generally intake backfire's are caused by timing issues or fuel puddleing but your's maybe somethng as simple as a vacuum leak?
g/l.
Old Mar 14, 2010 | 01:02 AM
ddsbadz's Avatar
i had intake backfires do to cam lobe worn on intake lobes valves not opening and backfiring threw intake (engine builder put wrong springs in my heads to much pressure on cam wore lobes off)
Old Mar 14, 2010 | 12:31 PM
Boman6760's Avatar
Great. This sounds like more and more fun. Time to start searching through some things I suppose.
