Sponsored by: CARiD
anti-freeze prob
Old Apr 8, 2010 | 10:32 AM
xxr98's Avatar
Default anti-freeze prob
my problem is. my car keeps over heating. i put anti-freeze in it and about 2 weeks later i have to put more in it because its all gone. i looked for leaks and spot on the ground when i leave places and nothing. i have no clue where its going. at first i thought i just needed a new thermostat, but that wouldnt answer the question as to where the anti-freeze is going. any ideas?
Old Apr 8, 2010 | 10:44 AM
THE SHOP's Avatar
You have a leak. Go to any parts store borrow their coolant pressure tester pump up the radiator then look for leaks.
Old Apr 8, 2010 | 11:17 AM
eseibel67's Avatar
If it's leaking, it might not leave a puddle because it evaporates quickly on a hot engine. Check for telltale stains on the engine. Pressure tester will I.D. the leak.
Hopefully it isn't a leaking head gasket, and the engine is burning the antifreeze out the tailpipe.
Old Apr 8, 2010 | 11:21 AM
THE SHOP's Avatar
If he keeps topping it off it will be a head gasket soon enough
