Sponsored by: CARiD
Skip when coming to a stop?
Old Apr 25, 2010 | 01:33 AM
TZ2884's Avatar
Default Skip when coming to a stop?
Recently I bought a 2000 b4c camaro, sometimes after running for a little while when I come to a stop the engine seems to be skipping. Once its skipping I can touch the gas pedal and it goes away. I was wondering what might cause this to happen. I was just hoping for some advice on where to start looking for the problem. Thanks in advance for any help.
Old Apr 25, 2010 | 02:51 AM
thirdgengta350's Avatar
sounds like it could be a small vacuum leak. engine vacuum decreases as rpm's increase. it could also be a few other small issues but vac leak sounds most likely personally. check all your vac hoses etc for leaks and you may find your problem. good luck
Old Apr 25, 2010 | 12:47 PM
TZ2884's Avatar
Thanks a lot. I'll have to check that out.
