Sponsored by: CARiD
A/C Questions
Old May 2, 2010 | 04:16 PM
TORCHD 02 TA's Avatar
Question A/C Questions
I went to use my A/C yesterday jsut to see if it was still charged. Low and behold it was empty
I bought the car in 7/2005, A/C has always worked fine. I hardly ever use the A/C. Prolly since I have owned my Trans Am I have used the A/C ~25 times..
So what would make my A/C system have a leak? The car is not my DD, only has 49K miles on it.. Any ideas? Kinda pisses me off to know that my A/C is gone when I take excellent care of my car.. I really hope I don't have a leak..
Thanks
Old May 2, 2010 | 08:56 PM
WS6-R's Avatar
Theres no freon?
Check the lines and replace if you see some oil sipping from them.
even though you have 49K is still a 8 year car and hoses crack when theirs barely any use. Just like tires....they get old and crack.
I would check the lines, replace if leaks and is good to replace the valve(filter) before adding freon again.
And hope is not the compressor.
good luck
Old May 2, 2010 | 11:38 PM
Originally Posted by WS6-R
Theres no freon?
good luck
Well I'm not sure if there's any freon. I turned the A/C on yesterday and it was warm.. Had a little coolness to it
I doubt the hoses are cracked. Everyhting in my engine bay is pristine lol
Old May 3, 2010 | 05:45 PM
WS6-R's Avatar
is the compressor turning on?
Old May 3, 2010 | 06:35 PM
Didn't have it on long enough to see if the compressor kicked on.. I am sure it did.. Prolly about a 1 lb low
Old May 3, 2010 | 09:01 PM
fleetmgr's Avatar
Thanks
Like any other machine, it needs to be run to stay in good condition. The compressor seals will start to leak if it just sits.
