Sponsored by: CARiD
t-top noise?
Old Oct 27, 2002 | 06:27 AM
z28man's Avatar
Default t-top noise?
i have a 2000 camaro and i get a like rattle noise or it sounds like the plastic is hitting the glass noise in the passenger side t-top. anyone else have this problem and what did you do about it?
Old Jul 22, 2019 | 10:05 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
You may need some lubricant on the t top gasket (silicone). The gasket may have shrunk due to it being dry.
Old Jul 22, 2019 | 11:56 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
My '02 Z28 used to do that in very cold (winter) weather, but only until the interior warmed up a bit (using the heater). I never did anything about it since it wasn't an issue most of the time.
Having said that, I can't imagine it's very cold in PA right now, so your issue might be an actual problem. Have you ever checked to make sure that the brackets (car side) for each rod end of the t-tops are tight and adjusted properly? Over time, these brackets sometimes loosen and get pushed outward as the t-tops are removed and reinstalled. I think some folks have also complained about the key cylinder rattling within the t-top itself. I'm sure there might also be other sources of potential rattles which I've forgotten.
