disappearing coolant
I had a leak on mine about a year ago. Turned out to be the lines that run coolant through the TB. I did the TB coolant bypass and I didn't notice a small crack in the rubber tubing, which led to coolant dripping out little by little until it was eventually empty. Check all your lines that coolant runs through first for cracks, that should be your first step.
But if you do decide to do a radiator pressure check......make sure you remove all 8 spark plugs first. If it is your gasket thats leaking, you may fill a cylinder with coolant during the test, then when you start the engine you could hydralock it and then you might have to buy a new engine.
