Sponsored by: CARiD
C0035 and U1040 codes...
Old May 13, 2010 | 05:40 PM
HAZ-Matt's Avatar
Default C0035 and U1040 codes...
This is actually for my sister's 2002 Aztek. It has an ABS light and so I connected HPT to it and got those codes...
[Brake] C0035 - LF Wheel Speed Circuit Malfunction (History)
[Unknown] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
My question is that is the U1040 error because it cannot communicate with a bad wheel speed sensor on the left front? Or should I be looking at something else like the module for the ABS itself. The WSS are part of the hub and wouldn't be too hard to replace but I didn't want to go slap on a $100 part if it won't do anything. Is this just a bad sensor or do you think it is something in the circuit?
Thanks
Old May 13, 2010 | 05:58 PM
mwg2600's Avatar
If the sensor is external look at it and see if its covered with metal shavings. If not..... The loss of class 2 with the abs seems like a wire or smothang
