Sponsored by: CARiD
bad alternator?
Old May 15, 2010 | 11:09 AM
slayerized6's Avatar
Default bad alternator?
Recently I've been having some trouble with the T/A. First off, the mirror lights flicker when I unlock the car, but they stop flickering and remain constant once I turn the car on. Second, my car will sometimes have no power in the lower RPM's. From a standstill and engaging 1st gear, Ill have the clutch 50% engaged and then my car bucks like it has no power. If im rolling through a stop sign, i shift into 2nd at lower rpms fine (1100rpms), however, once i try to give my car some gas, the engine just lugs.
I test the battery/alternator with a mulitmeter and found these readings:
13.6v - Engine shut off
14.5v - Engine running
Howver, my indash voltmeter reads lower than those readings
Also, I dont know if this has any significance, but when I plug in an obd2 scantool connected to m laptop, the volts AND the oil pressure readings on my dash jump considerably.
I changed the fuel filter yesterday, but that didnt cause anything. Air filter looks cleans. What could this problem be?
Old May 15, 2010 | 06:07 PM
fleetmgr's Avatar
Not sure what you're problem is, but it isn't the alt.
Old May 16, 2010 | 10:25 PM
98pontiac's Avatar
need more info. any codes?
