Sponsored by: CARiD
two issues with my ride
Old May 20, 2010 | 03:51 PM
Joe_1006's Avatar
Default two issues with my ride
One, what is the normal oil pressure on 99 trans am while in idle at normal operating temperature? while at red light i notice the needle on the oil pressure gauge hovers erattically between the 20 mark and the 30-35 mark. However, when I am cruising the needle hovers normally around the middle mark 40 or so. I've checked my oil level and it seems just fine, i changed the oil about 3 weeks ago.
Two, my trunk release motor seems to be dying on me. When I press the release button on either the remote or the one inside the car, the trunk motor makes a awful screeching or grinding sound and will not release the trunk open. I have to manually open the trunk
any suggestions?
thanks in advanced
Old May 20, 2010 | 11:51 PM
Reaperchild's Avatar
don't qoute me on this but stock ls1 oil pump is really a pain in long life terms ... what oil do u use ??
trunk issue ... pull the carpet .. check what's wrong with the tall steel thing that releases ur trunk ...IDK what its called =)
Old May 21, 2010 | 12:22 AM
LS6427's Avatar
You're good. These things bounce around sometimes. About 40 psi cruising is great. Don't put too much trust in the guage as far as the actual number, just use it to make sure its making pressure all the time. It can get LOW on hot days at idle down here in South FL.
Down here in hot *** S. FL...I have been using 20w50 personally, my motor has loved it for the past 8 years and still does. Maybe try it out, it can only help pressure, it can't hurt anything.
any suggestions?
thanks in advanced
Sounds like its shot than. Mine has been working since I bought the car...but for about the past 6 years when I press the button or my remote on my key chain...its a slug. Its like 1 full second to release it. But it does every time.
