Sponsored by: CARiD
Could it be my vats?
Old May 21, 2010 | 10:26 AM
Slash8915's Avatar
Default Could it be my vats?
So today, I was driving to work, and my car just died as I was driving. I pulled over and started it back up, then went on my way. I got to the turning lane right in front of my work, and it died again. THIS time, whenever I tried starting it up, it would start, idle at about 100rpm, then die. It did thid over and over about 20 times. I waited a few minutes, then it started right up. I drove into a parking spot, then as soon as I parked it, it died again.
Could this be my vats shutting off the fuel?
Old May 21, 2010 | 12:31 PM
99monguse's Avatar
just for the hell of it, swap your IGN relay with on eof the fan relays (they are the same). See if that helps!
Old May 21, 2010 | 03:13 PM
HotSilverBird's Avatar
Its not vats....
Old May 21, 2010 | 08:16 PM
Slash8915's Avatar
Originally Posted by HotSilverBird
Its not vats....
Any idea what it COULD be? I'm assuming it's an electrical issue.
Old May 26, 2010 | 07:06 AM
My2000Z28's Avatar
its not the vats. the wires in my ingnition cylindar when out multiple times. it just wont start. if it starts it will stay running even if you cut the wires.
