Sponsored by: CARiD
forgot where this part goes.. help please
Old May 27, 2010 | 02:43 AM
5.7Blackz28's Avatar
Default forgot where this part goes.. help please
Alright so i tore the motor down to the block and remember where everything goes except this big vacuum hose. I really checked the whole motor for 30 minutes and could not figure out where this goes again.. Oh yeah i only worked on the passenger side so disregard n e driver side possibilities, unless it goes from passenger side to part of the drivers side. If you can give me a really good detailed spot where this goes i'd appreciate it even better if some one can just load a pic and use paint to make arrows that point to where they go and make it dummy proof. thanks in advance guys, i really appreciate it, trying to get this back together so i can leave base and spend memorial day with the family..
Old May 27, 2010 | 04:23 AM
hopefully this link works for the picture..
https://ls1tech.com/forums/attachmen...1&d=1274952056
Old May 27, 2010 | 11:24 AM
bjamick's Avatar
That looks like the PCV setup to me. The larger end goes to the drivers side valve cover in the very back, which is connected to the PCV valve. Then the first connector after that connects to the passenger side valve cover. The last part should go to the last nipple deal on the front of the passenger side valve cover.
Old May 28, 2010 | 01:10 PM
litle88's Avatar
yup, what he said!^^^^^^^^
