Sponsored by: CARiD
Torque arm problem?....
Old May 30, 2010 | 02:57 PM
Poppn's Avatar
Default Torque arm problem?....
is it normal to hear a thud on the floorboard after a tunnel mounted torque arm setup is installed?
it only seems to happen on DEceleration (such as jumping on the gas quickly in 1st gear and letting off) and coming to a complete stop.
also, 9 out of 10 bumps i hit, it makes the thud sound also (i figured this is normal)
checked all bushings, mounts, bolts and nuts and have just about given up. i don't mind the sound so long as there isn't anything seriously wrong
Old May 30, 2010 | 03:20 PM
BOA279's Avatar
you need to check your transmission mount. bet you $ its kaput. Could also be your exhaust smacking the floor
Old May 30, 2010 | 03:32 PM
Poppn's Avatar
Already checked the mount, its a poly one, no cracks or anything. If it were the exhaust, where would it be? It's stock manifolds and y with a magnaflow catback
Old May 30, 2010 | 03:42 PM
1993 z28 f1's Avatar
Hey:
Yep thats pretty normal with a tunnel mt TA, mine does all the time. I got use to it after a few thousand miles now I barely notice it, but the wife does when shes in it. Also you'll notice more road noise and the road bumps more just the way they are.
Dub
When In Doubt Do Without
