Sponsored by: CARiD
Please read need help saving $$$$
Old Jun 15, 2010 | 07:15 PM
WS62077's Avatar
Default Please read need help saving $$$$
Well I successfully changed my knock sensors, but not before successfully breaking nearly everything else. It is easy to say I learned some lessons.
1) Dont gorilla the manifold, you WILL break the oil pressure sensor.
2) You cant take off the manifold without removing all hoses.
With that being said. I broke the 3 hose system on the back of the manifold. GM calls it the PCV type????? they want 138 bucks for a simple hose. This is what I need help with. I just broke one piece. Can I go get hose from the store and fab it. Or do any of you pros know were I might pick up a another one. Or do any of you know a better name for these hoses. Any feed back will be greatly appreciated. I put a picture in here for you, its the one that looks like a Y. Found out its also called a PCV Harness Hose.
Old Jun 15, 2010 | 07:55 PM
SWEET98SS's Avatar
Yes, you can use regular hose and fittings. I put a catch can on mine and did all rubber hose and just went to autozone and got plastic fittings. You can make that whole setup from autozone parts, they have a section with T's and y's that are plastic. You can also use metal if you want.
Old Jun 15, 2010 | 10:45 PM
09camaro383's Avatar
use regular hose and clamps it will be ok!! you are not the only one that has broken the oil pressure sensor!! I've also done it!!
Old Jun 16, 2010 | 06:54 AM
SWEET98SS's Avatar
I also broke the oil sender. I didnt realize how far back I had the intake.
