Sponsored by: CARiD
bad ground?
Old Jun 18, 2010 | 01:23 PM
slo_lt1's Avatar
Default bad ground?
I need help tracking down a bad ground, were are they all located?my negative terminal got fried i though my headers melted the battery cables but there fine.i heard a bad ground will also do this.no fuses are blown it went straight for the battery.i need to get this figured out fast, im trying to sell the car so now my hands are tied since no one can test drive the car im going to get lowballed like a motherfu(ker. thanks for any help
Old Jun 18, 2010 | 03:38 PM
nimrod.sixty9's Avatar
G100 (V6 VIN K) On the lower right side of the engine, above the A/C compressor
G100 (V8 VIN G) On the lower right side of the engine, above the starter solenoid
G101 In the engine compartment, attached to the front of the left wheelhouse
G102 In the engine compartment, attached to the front of the right wheelhouse
G105 Attached to the top right side of the radiator support
G106 Attached to the top left side of the radiator support
G109 Attached to the left front frame rail, forward of the brake pressure modulator valve bracket
G110 (V6 VIN K) In the front of the engine, bolted to the pulley above the A/C clutch connector
G110 (V8 VIN G) Attached to the rear of the drivers side cylinder head
G111 (V6 VIN K) Attached to the left engine mount
G111 (V8 VIN G) Attached to the lower left side of the engine, behind the generator
G112 Attached to the rear of the left cylinder head
G200 Near the left A-pillar, bolted to the IP mounting stud behind the kick panel
G201 Near the right A-pillar, bolted to the IP mounting stud behind the kick panel
G202 Attached to the floor pan under the center console, rear of the inflatable restraint sensing and diagnostic module (SDM)
G305 Bolted to the left rocker panel at the floor pan bar
G310 Bolted to the roof, left of the dome lamp
G320 Bolted to the roof, left of the dome lamp
G400 Bolted to the rear compartment lid release actuator bracket in the rear compartment
Old Jun 18, 2010 | 04:34 PM
slo_lt1's Avatar
Thank you! now hopefully it doesnt take me to long to find
