Sponsored by: CARiD
How to Adjust Driver Window!?
Old Jun 25, 2010 | 02:25 PM
BFarrier's Avatar
Default How to Adjust Driver Window!?
ok i have a 2000 camaro z28 and the driver window rolls up fine its just that right above the mirrior i can see daylight and it doesnt leak when it rains only when i wash the car. so i was curious if i can adjust the window so it rolls up higher so i can seal that gap like on the passanger side. thanks
Old Jun 25, 2010 | 02:45 PM
ROCNDAV's Avatar
http://shbox.com/1/adj_window.html
Old Jun 26, 2010 | 10:41 AM
wssix99's Avatar
Save the manuals!
.... before you try a "fix" make sure you don't have this problem. If you do, adjustments won't help:
https://ls1tech.com/forums/general-m...-included.html
So, yes - you can adjust the window, but it doesn't "unadjust" itself. Either someone messed with it or a component is breaking.
