Sponsored by: CARiD
AC problems
Old Jul 2, 2010 | 01:07 AM
Coonass350's Avatar
Default AC problems
hey guys, my A/C stopped cooling last summer, so me & a buddy who is an automotive technician, "recharged" it with new refrigerant. well it worked all last summer but now this summer sometimes it will work & blow ice cold then just start blowing warm/hot air. if it starts blowing warm/hot air & i give it gas(stomp the pedal to the floor) it will start blowing cooler/cold air again for just a couple minutes then start back on blowing warm/hot, can anyone give me some tips/advice/info to help fix this problem. i would really appreciate it. thank in advance guys
-Brenton
Old Jul 2, 2010 | 06:15 AM
fleetmgr's Avatar
You have a leak that needs to be fixed, that's why it was low to begin with last year. Chances are, fixing it will entail a new compressor.
Old Jul 2, 2010 | 07:31 AM
FiredUpZ28's Avatar
Way to jump to conclusions.... how about the OP gets the system leak checked before buying any parts. No sense in shelling out 100 bucks on a compressor when it was just a 2 dollar seal..... If the system cools after giving it gas you may have a compressor clutch failing as well. Either way get the system professionally checked - shouldn't cost too much.
Old Jul 2, 2010 | 07:43 AM
fleetmgr's Avatar
You figure the odds.....a compressor seal, as it's the only moving part in the system, or a static seal. Odds favor the compressor. So does 35 years of experience repairing A/C systems.
Old Jul 2, 2010 | 08:25 AM
samson_420's Avatar
^ I am with this guy. . . . A compressor is a very likely culprit.
But, still check it out before you tear it open and start throwing parts at it.
Old Jul 2, 2010 | 08:37 AM
Coonass350's Avatar
alright i sure will. thanks guys.
