Sponsored by: CARiD
Squeaking in between gears/turning
Old Jul 9, 2010 | 04:06 PM
96blackta's Avatar
Default Squeaking in between gears/turning
When I start rolling in first, shift gears, or make a turn I can clearly hear an annoying squeaking/creaking noise. It sounds like it's rocking, because I can hear it squeak back and forth like. Even with the windows up, I can hear it perfectly clear inside the car. It seems like the noise is coming through where the shifter is. I checked out the shifter itself, but nothing below the lower shift boot, so I believe it has to be under the car.
Old Jul 10, 2010 | 09:28 PM
96blackta's Avatar
Bump?
Old Jul 11, 2010 | 06:06 AM
Nebu's Avatar
transmission mount?
Old Jul 15, 2010 | 09:46 PM
96blackta's Avatar
It was the tranny mount. One of the bolts that mounts to the undercarriage was loose, one was missing, and the bolt that holds the mount to the tranny was loose. Squeak free now.
