Sponsored by: CARiD
Trying to replace coolant level sensor.
Old Jul 10, 2010 | 11:37 AM
99T/A_Marine's Avatar
Default Trying to replace coolant level sensor.
How the **** is this supposed to fit? I've tried pushing it in, and putting vaseline on the o-rings and it still doesn't want to fit. Any suggestions?
Old Jul 10, 2010 | 12:18 PM
Ok, now I took another look and the o-rings on the new one are thick as hell compared to the factory unit. Is it possible for o-rings to flatten out over time because the factory ones look really thin. If not then is it ok to just reuse the o-rings on the new sensor?
Old Jul 10, 2010 | 12:48 PM
fleetmgr's Avatar
Sounds like the wrong sensor. I wouldn't reuse old orings...ever, and yes old orings do get flat spots over time.
Old Jul 10, 2010 | 12:54 PM
It's not the wrong sensor because it looks the exact same in every way with all of the same connections. With the o-rings, I mean the entire thing is flat all around. Not just in one spot. It looks as if they were made like that. Do they sell different o-rings or something?
Old Jul 10, 2010 | 04:08 PM
fleetmgr's Avatar
The flat all around is what I'm talking about. In cross section, a new oring is round also...with no flat spots anywhere.
I say wrong sensor because of the wrong orings...perhaps mispackaged or something like that. Sure wouldn't be the first time that happened.
Old Jul 10, 2010 | 04:50 PM
I just said **** it for the time being and reused the old o-rings for now. If it starts leaking then I'll just go to a stealership for the sensor next time instead of advance. Thanks for the help though dude.
