Sponsored by: CARiD
A/C vents
Old Jul 15, 2010 | 02:55 AM
Brian'sCharlotte(TA)'s Avatar
Default A/C vents
Alright, so today I got in the car for a little drive to the bank and when I turned on the A/C I noticed that the setting was set to Max AC... However, the air will only come out of the defroster vent and the floor. It's like the mechanism inside the dash is stuck and will not move no matter what setting the switch is on. Anyone ever had a problem with this? Fuse or something maybe? I'm just hoping that motor isn't out.. That would probably suck to replace. My BCM has also been acting up I'm guessing my solter didn't hold because occationally my radio will turn off and my windows won't work. Anyone know if the Air vent director is also connected to that?
Old Jul 15, 2010 | 10:15 AM
slow's Avatar
check for a vacuum leak at the connector near the pcm.
Ryan
Old Jul 15, 2010 | 10:35 AM
dubga's Avatar
This problem is fully explained at www.shbox.com.
