RPMs dropping.. any ideas?
I've talked to a couple A techs and they said I should clean inside the throttle body area.. I'll probably just do the 3 step fuel induction cleaning kit that cleans out the injectors and throttle body and uses a gas tank treatment.. Where is this idle control valve? Is that the same as the IAC motor on the throttle body?
