Sponsored by: CARiD
High Idle and a hesitation
Old Aug 8, 2010 | 08:00 AM
MaroMan's Avatar
Default High Idle and a hesitation
I have a 2000 ss with longtubes cam and a stall.
I just recently started having a problem where once i reach about 50 mph the car seems to hesitate or "stutter" like the car starts bucking until i give it a little more gas.
Also once i come to a stop and put the car in park, the the idle jumps to about 1800 rpms until i turn the car off.
Any ideas on what could be going on? No codes are being thrown
Old Aug 8, 2010 | 07:38 PM
IRONFIST's Avatar
It should throw a code... at least a "high idle" or something...
I'm thinking vacuum leak right now, but without a code it's hard to tell.
Old Aug 10, 2010 | 07:14 PM
MaroMan's Avatar
Yeah thats whats killing me, a code would be so nice right now lol
Old Aug 11, 2010 | 05:43 PM
MaroMan's Avatar
It only seems to happen when its hot out. What the hell is going on...
Old Aug 12, 2010 | 07:46 PM
MaroMan's Avatar
Blahhhhhh nobody has any ideas
Old Aug 12, 2010 | 09:12 PM
bad98ls1camaro's Avatar
throttle position sensor?????????
Old Aug 12, 2010 | 09:27 PM
MaroMan's Avatar
Thats what im going to replace tommorow.
Old Aug 12, 2010 | 09:37 PM
whtrashferrari's Avatar
Default hey
make sure you go with the cheap tps not the spring loaded one.. I have had some issues with the spring loaded one made by bwd i believe it is! consistent high output tps codes i tried 2 of them so im gonna say stay away from that style.. just the normal cheap tps works the best for me!
try cleaning the maf too!!
sometimes a high idle can be a vacuum leak!! spray a little carb cleaner around the engine intake and tb ares and see if the idle changes ..easy way to find a vacuum leak
lots too look at ! good luck to yah!
Old Aug 13, 2010 | 03:58 PM
MaroMan's Avatar
Changed tps still no luck... dammit
Old Aug 23, 2010 | 03:33 PM
MaroMan's Avatar
Bought an iac and iat sensor. Going to replace those and do an oil change because it needs it. If those do not fix it then im doing the o2 sensors. Just sucks that im going to spend over $400 in non returnable parts and might still not fix the car.
But a new peice to the puzzle, when the car is doing about 55 now it starts bucking really bad and i lose all gas, i can push the pedal to the floor and get nothing, BUT if i put it in neutral it revs just fine. Any ideas?
Old Aug 23, 2010 | 10:06 PM
eseibel67's Avatar
Save the money you are wasting on parts and check the data streams on a scanner. Have the O2's checked first.
