Sponsored by: CARiD
AC does not work every single time.
Old Aug 12, 2010 | 12:46 PM
wrd1972's Avatar
Default AC does not work every single time.
AC has been working fine for quite some time. Today I started it up and the compressor would not kick in. Scanned for codes and had a 16 which is low res ignition and has nothing to do with AC.
Reset the codes, started the motor and the AC worked fine.
What will cause the AC to occasionally, not work right?
Old Aug 12, 2010 | 01:54 PM
SOMbitch's Avatar
Worn out compressor clutch can cause this.......
Old Aug 13, 2010 | 02:12 PM
slow's Avatar
electrical connector issue on the clutch can cause this as well, I had to replace the terminals on my 98 ws6 for this issue, drove me nuts for weeks until I replaced the terminals, and perfect after that.
Ryan
Old Aug 13, 2010 | 03:17 PM
BOA279's Avatar
what they said. Sticky clutch or potentially bad pressure sensor/wiring
