Sponsored by: CARiD
Old May 18, 2016, 05:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Alternator removal help...
Old Sep 11, 2010 | 05:59 PM
sjsingle1's Avatar
i am lucky......the truck alt upgrade does not have the pesky 15 and 13mm bolts and bracket anymore
Old Oct 28, 2012 | 05:32 PM
JakeFusion's Avatar
Super Hulk Smash
I know this is old but I'm in the process of replacing my alternator. Did you guys work from the bottom or top? I'm working from the top and I've removed the two 15mm and one 13mm bolt but can't pry it free. Do I need to yank from the bottom or just try to turn it and pull forward?
Old Oct 28, 2012 | 06:41 PM
sjsingle1's Avatar
take the whole bracket OUT .......thank me later
Old Oct 28, 2012 | 07:24 PM
JakeFusion's Avatar
Super Hulk Smash
I can only see two bolts for the bracket. There has to be more than that? Looks like one from the passenger side and one from the front sort of in-between the two 15mm for the alternator?
Old Oct 29, 2012 | 01:17 AM
JakeFusion's Avatar
Super Hulk Smash
Taking the bracket out is what's needed. Actually, I just loosened it quite a bit and was able to work the alternator out enough to get to the exciter plug and get that off.
Looks like I am going to have to jack the car up to get the power connector off as the alternator fell through to the floor (I have it supported so it's not pulling the connector). Otherwise, I don't see how I can possibly reconnect the exciter, the power line, and then get it lined back up from the top. I foresee taking the bracket all the way out and getting everything started on it before trying to re-position everything.
