Sponsored by: CARiD
Help with a problem.
Old Sep 8, 2010 | 06:46 PM
99WS6T/A's Avatar
Default Help with a problem.
My LS1 has a small oil leak nothing major have had it for 2 weeks but every time i check my oil its fine. It always at the same spot every time i check it. So i was wondering what i should put in there to stop the leak. I was gonna use some Lucas Stop Oil Leak cause I here its the best for everything, Should that work in stopping my small oil leak or can you guys recommend anything better to stop it.
Old Sep 8, 2010 | 07:16 PM
LS-1Z28's Avatar
do not add additives to your oil
If it's bad you will need to replace the leaky gasket/seal. If it's a very slow drip just keep an eye on your oil.
