99 ls1 camaro MAJOR ISSUES
got a bunch of issues going on with my 99 z28.. Its throwing 8 codes.. I wrote them down and left it at work.. just wanna get the thread started.. the ones it was throwing i remember.. was an oxygen sensor, tcc lockup, shift solenoid, bout 4 different codes for transmission, and egr code, injector circuit open code.. Also the cooling fans were working only on low speed and quit completely its the like the car has a bad ground somewhere on the left side but ive traced it all down and came up with nothing.. Also the car stumbles and misses horribly.. idles at 1000rpm then down to 850 where its set at.. and the torque converter feels like its stuck in lockup mode.. Just yesterday it ran great.. i pulled out from work and it just started missing, cutting out, and breakin up real bad.. then didnt want to shift gears, so i drove 1 mile back to work parked it and been looking for issues.. i tried shaking all the wires on that side around with the car crunk.. tried moving the pcm around, battery connections.. .. its almost like it runs ok for a sec then goes back to runnin crappy.. it also makes a banging noise taht sounds like the headers are hitting against the kmember.. im thinking torque converter has crapped out.. as im running a cam with stock converter.. but curious as to why all the other codes would be thrown and why the engine itself runs so poorly. now.. ANY SUGGESTIONS?? ill post the exact codes its throwing tomorrow when i get to work..!!
thanks for help in advnace!
