Sponsored by: CARiD
passenger window wont go down
Old Oct 15, 2010 | 10:42 PM
rxrom's Avatar
Default passenger window wont go down
The passenger window is up and will not go down. the power window switch on both the driver and passenger dorrs does nothing. Is the problem one of the switches, a motor, or is there a realay or fuse. The riverside window is fine.
This is a 2000 trans am convertible
thanks
Roman
Old Oct 16, 2010 | 01:53 AM
Wicked_muscle's Avatar
Was your window going up and down slow before it stopped working? If so, then the motor is most likely the culprit.
Old Oct 16, 2010 | 02:32 AM
myk's Avatar
myk
Wait like a half hour or so and then go back to the window-does it work now, even if slowly? If that's the case then it's your motor. If it still doesn't work let us know...
Old Oct 16, 2010 | 09:08 PM
rxrom's Avatar
Doesn't work at all
I just bought the car so I don't know when window stoped working
Old Oct 16, 2010 | 09:21 PM
Jeresous's Avatar
GM window motors are absolutely horrid. Both of mine have burned out, and it seems all F body window motors burn out sooner or later. My first assumption would have to be the motor. Kind of pricey to replace too, unfortunately.
Old Oct 18, 2010 | 01:47 PM
rxrom's Avatar
fixed the problem. I changed the driver side window switch. Got lucky!
Old Oct 18, 2010 | 04:53 PM
Ghostintheshell's Avatar
The guy I bought my last Trans Am from replaced both window motors before I bought it.
Thank god he did. My FIRST trans am had a slower moving drivers side window.. always went up - but made me nervous.
