1998 WS6 OBD Code 0442
They have replaced:
Gas Cap
Gas Tank Pressure Sensor
The Service tech is giving me the run around about the gas tank 'possibly' being the problem because there is some slight corrosion around the joint where the filler neck meets the gas tank. He tells me that GM does not make this tank anymore and there are no 3rd party manufacturers that make this tank. It seems to me that the Techs don't know what the heck they are doing in trying to troubleshoot this problem because there is more to the EVAP system than just the gas tank....
Thoughts, comments, and suggestions would be greatly appreciated.
do you have access to a smoke machine?
check for cracked vacuum lines and a bad or weak fuel tank pressure sensor or purge valve
i would not rule out a small pinhole where the corrosion has built up on the filler neck due to the fact it would cause identical symptems as a bad gas cap.
hope this helps!
Edit: I'd find another shop if I were you. The leak's almost impossible to find if you're doing this in your driveway, but a shop, a "dealership" should have the tools and experience to find it like, yesterday...
Thanks for all the help!
